Jetting following addition of a reed valve?
alanscottj
Been out for first rideout today after fitting reed valve. Scoot is running great and egt and cht is in a good place. I was told that I would have to up jet after adding the valve, as my scoot was already running rich I think it is ok in terms of main jet. But, when I was on the rideout and started her up to leave she stalled twice and was difficult to restart. Once it started I had to run with choke on for a minute or so to keep her going. Once I got going she was running pefect.
So, given that I have added the reedvalve what recommendations has anyone got in terms of my jetting? Needle clip position etc.... Carb is a delly 30mm PHBH.
Any thoughts muc appreciated as always :-)
Norrie Bodge
have you altered the piston & added boost port in cylinder too alan?
gonna eventually change to 30mm Delly from Amal & a mate of mine suggested this for starters
X7 Needle
Av244 Atomiser
55 Pilot
125main
alanscottj
[quote="Norrie Bodge"]have you altered the piston & added boost port in cylinder too alan?
X7 Needle
Av244 Atomiser
55 Pilot
125main[/quot
Yes mate, boost port and piston has had windows and skirt cut. Runs great but not great starting.
Muppet
266
Cโ€™est la vie
alanscottj
[quote="Muppet"]266[/quote
266 ???
Muppet
ya have av244 :? mabee it is av264 try av266 mite be betta ;)
Cโ€™est la vie
alanscottj
For poor starting would I be looking at the pilot?
squeakmillward
for about ยฃ80 I would get it on the dyno cheaper than a holed piston or seize
alanscottj
squeakmillward wrote:for about ยฃ80 I would get it on the dyno cheaper than a holed piston or seize
I think I'm set up safe through the Rev range. According to my EGT and CHT I am ok. My temp never went over 530 whilst sitting at 65, my only issue is when starting.
Norrie Bodge
Did you get your jetting all sorted Alan?
    Users browsing this forum: No registered users and 22 guests
