Building a new engine
Snails wrote:
storkfoot wrote:
Conrods Both my cranks have been built there (Indian GP 200 webs, Kawasaki [110] and Yamaha [115] rods) a few years ago now, in the case of the Kawasaki one).
Is Grampions in the Crosby / Waterloo area?
Paul can you remember which Kawasaki the 110 rod was from? KE175D?
Yes Snails, Grampian is in Crosby. L23 0UB. I'll be paying them a visit next week.
storkfoot
Ed, as Martin has said, yes, they are in Crosby. They can be a funny lot but if you get any attitude, just ask to see the boss. He was a gent :)
Martin, I've just found my notes about this conrod which I wrote down after speaking with Ian Frankland. Yes, it was the KE175D. The benefit of this rod over the Yamaha was that it fitted into Indian webs at 15mm wide with no machining - the overall width was 40.5mm. The downside, in comparison to the Yamaha rod, is that it's not quite as sturdy. I took the view that a KE175 could probably produce the power of a TS1 :?: so it was good to go. Over 4 years and many thousands of miles later, it still appears fine.
elb1
Main scooter: eibar s2 li150
Hi snails I've used these guys based in Oldham for some bearings. Power transmission. https://www.google.co.uk/url?sa=t&sourc ... _u4d7GbLrQ
Very reasonable too ;)
Snails
elb1 wrote:Hi snails I've used these guys based in Oldham for some bearings. Power transmission. https://www.google.co.uk/url?sa=t&sourc ... _u4d7GbLrQ
Thanks. Still needed to source them so thats good.
Snails
I've not made a massive amount of progress recently, however I did try and clean up the gear cluster I posted pictures of earlier. Having done this I don't think its a good idea to use it :(
I'm wondering if I can get away with a SIl gear cluster (10-12-16-18 Teeth) rather than finding another original item
I guess this boils down to two questions
1. will it fit and work with my Italian gear box (50-42--39-36)
2. What effect will that have on performance?
As already said , get your original cluster repaired. It will be far better.
Snails
wack 63 wrote:As already said , get your original cluster repaired. It will be far better.
Yeah I was actually thinking that after I posted my question. Probably cheaper too.
One of these
then find a local machine shop to fit it
Snails
Talking of removing the gear cluster track. Has anyone any experience of using one of these?
http://www.ebay.co.uk/itm/251690206165? ... EBIDX%3AIT
Not that particular one but have one similar that I've used a few times. you need to get the casing hot enough that it will boil spit then slap enough grease in to fill the hole offer up the tool and give it a sharp rap with the hammer, it should start to push up. If not reheat and try again.
Sometimes if you get it hot enough fast enough they just fall out if you turn the casing over nad give it a knock on the bench.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 5 guests
