Fitting Li ramp - need to remove end plate or not?
alanscottj
- registered user
- Main scooter: Lambretta GP SS250 Casa
- Contact:
The saga of the kickstart engaging continues and I have decided to have a go at fitting an Li ramp whilst the side casing is off. I know what I have to do and am wondering if it is possible to cut off the ramp of the end plate with it in situ. Maybe with a cutting disk on my dremel? Any thoughts???
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox ๐๐
All those filings in your gearbox and clutch,
I wouldn't advise it.
Remove, cut, smooth and reshim gearbox.
alanscottj
- registered user
- Contact:
Yeah, I thought about that! Haven't removed one before, a bit nervous tbh, especially as engine has recently been built.lambro wrote:All those filings in your gearbox and clutch,
- registered user
- Contact:
Got to remove the endplate.
alanscottj
- registered user
- Contact:
Looks like it, is it a hard job?Adam_Winstone wrote:Got to remove the endplate.
- registered user
- Contact:
No, take the clutch off, loosen and remove the nuts and use two m6 bolts or t bars to jack it off
alanscottj
- registered user
- Contact:
I have removed the clutch plates before to replace one of the clutch centre bearings, so there's not much more to do to take the end plate off then?rosscla wrote:No, take the clutch off, loosen and remove the nuts and use two m6 bolts or t bars to jack it off
hendy
- registered user
- Main scooter: lambretta li 125
- Contact:
I did my first one a couple of months ago. Not difficult, just took my time and read sticky', haynes and the lcgb guide 'alanscottj wrote:Yeah, I thought about that! Haven't removed one before, a bit nervous tbh, especially as engine has recently been built.lambro wrote:All those filings in your gearbox and clutch,
To be honest I spent more time reading than building my gearbox but it was worth it.
Don't be shy, get into it.
- corrado
- Dealer
- Contact:
The ramp tends to stick to the xmas tree when you draw it up with the T bar extractors stopping it from breaking free so tap the xmas tree gently with copper mallet to disengage it.
- registered user
- Contact:
If it does stick you can also give it a tap on the rectangular lump on the end plate in front of the bearing
