carb position
ducksta
T5 172cc engine 30mm carb sat on top of a malossi reed valve, in the original frame the carb faced forward but the Frame it is going in i can reverse it to face backwards will this change the performance.
ducksta
anyone :?:
ducksta
position at present
Personally I would leave it facing forward, just thinking that hung out the back it will be sucking in exhaust fumes and other shite kicked up by the rear wheel.
lambro
ducksta wrote:Image
position at present
If the manifold is matched to allow it to flow properly I don't see why you can't.
I have a 25mm on this:
And an SS90 rep with a rear facing 32mm, both work fine in the wet as well :)
OzOAP
Main scooter: Vespa PTS1E
No problem running backwards. My TS1 P Range has a rear facing carb.
The Quattrini 172 kit also does.
ducksta
will check it out if it looks ok, then rear facing it will be
You might also want to consider the access to the adjustment screws just in case the shock gets in the way ;)
