To richen you'd plug holes
My malossi 210 using a T5 24/24g carb
Was rich with BE3 emulsifier straight off the throttle so I changed to a BE2
& loads better now
Which is in line with chart posted above which suggests the BE2 2/4/7 is leaner lower down than the BE3 3/5/6.Norrie Bodge wrote:To weaken you'd drill a hole
& loads better now
Perhaps the person who labelled the chart really didn't know either?rosscla wrote:It doesn't align though with the picture labeled 'larger' to 'smaller' and suggests a progression.
That's kind of where I got to, maybe I should just have taken baz's word (sorry mate), but I'd started reading by thenGinch wrote: The more I read the less grasp I have!
emulsion tubes act as air brakes to slow down the flow of fuel
You are saying that BE2 is richer in high rpm than the BE3. The chart says the size of the holes in the top of the BE3 is 7.1mm2. The BE2 has much bigger holes at the top with 14.1mm2.freakmoped wrote: 2) be2 is enrichment in high rpm when the exhaust comes into resonance and needs/sucks a lot
