poor starting
LI150
Main scooter: Series 2 LI150
My series 2 with 200 engine 25mil carb and af clubman has always been temperamental at starting. It was starting first kick now it takes 20 plus. Initially I had a carb issue which I sorted. I have checked spark it appears weak to me. So what's failing. Electrics are not my strong point could it be stator ? CDI? I
Yes could be any of those.
First thing I'd check would be the plug gap, then try a new plug and work back from there. Cap, HT lead, CDI, remove the green to the loom from the CDI to eliminate a short or faulty switch. Swap the CDI for a known good one. Get a cheap multi meter and check the values on the stator wire against the published values.
If all that checks out then you're probably back to carburation.
mick1
Main scooter: Li Avanti 225
What's your timing set at ? could be over retarded ?
What choke jet you using ?......maybe up-jet ?
LI150
Thanks for the pointers will try it all
Muppet
choke?
C’est la vie
LI150
Choke is working so not that unless its choke jet. Need to do some more testing to eliminate
