Lambretta mag housing nightmare, all help appreciated !
Egger
Main scooter: Lambretta Li150 special
Its off !
Lots of heat, a bolt in the end of the crank and after a sound beating it finally it came out.
Thanks again guys much appreciated.
Egger wrote:Its off !
Well done that man....now you've done that you have the delight of removing the drive side bearing retaining plate, make sure you have a large. sharp edged screwdriver to hand 8-)
bazza3004
Or a decent impact driver as the screws can be as much fun as your flywheel housing was !
bazza3004 wrote:Or a decent impact driver as the screws can be as much fun as your flywheel housing was !
I really like the allen-head oil seal plate screws. Made of incredibly soft metal, which someone has loctited in place.,...just one turn to round the head off!
lambro
I used to do that,
Then I was on the receiving end the other week,
I will never do it again, promise.
gaz_powell
"I really like the allen-head oil seal plate screws. Made of incredibly soft metal, which someone has loctited in place.,...just one turn to round the head off!"
Ha ha had a few of them - nothing worse than opened an engine up and seen them rounded
Not so bad when brand new and you have a decent hex head tool to install and strip - i use a socket attachment not an allen key.
My last two builds i went back to sloted screws (from SR)
Gaz
Egger
:shock: Been staring at it for the last 20 mins wondering why I put myself through it !
bristolmod
cos its like a tall mountain innit " cos its there....."
If you use an Impact screwdriver thingy, make sure its body is not touching the inside of the mag housing area as you wack it- if it is touching its possible to put a burr or a slight indentation therein, which means a pig of a job getting the mag housing off again- I speak from bitter experience.....!
Chris
Scootering since 1968.
Muppet
Chris
fit an exstension bar to ya impact drivr from a 1/2" drive soket set
C’est la vie
