It probably isgoldeneye wrote:is it the nut behind the handlebars?
Wassel Failure
What type of tank to carb fuel pipe do you use?Did you change it when changing everything else?I had a similar problem to you,after trying all else swapped the fuel pipe.Hey presto that cured it.I believe the pipe was porous pulling air thru with the fuel.
- Information
Who is online
Users browsing this forum: Baidu [Spider], Google [Bot], Semrush [Bot] and 3 guests
