Wassel Failure
Bilko
Main scooter: LI150
goldeneye wrote:is it the nut behind the handlebars? ;)
It probably is :oops:
Bilko's Oily Blog
Bilko
Main scooter: LI150
ducksta wrote:get a m8 round try your bits on his scoot till his wont start
If this isn't sorted soon, I'll be starting the GP rebuild a lot sooner. I could use that. :lol:
Bilko's Oily Blog
Bilko
Main scooter: LI150
Mag housing off. partly grubby inside face, but nothing else. Crank out later.
Bilko's Oily Blog
Bilko
Main scooter: LI150
wack 63 wrote:As already said, do a leak test but I'd also check the crank especially the big end bearing.
Took the crank out and the Conrod has a good bit of play.
Bilko's Oily Blog
Bilko
Main scooter: LI150
The play is worse than any of the cranks I have, but how would induce almost impossible starting and spluttery revs when it ran for a few seconds?
Bilko's Oily Blog
roli-olo
What type of tank to carb fuel pipe do you use?Did you change it when changing everything else?I had a similar problem to you,after trying all else swapped the fuel pipe.Hey presto that cured it.I believe the pipe was porous pulling air thru with the fuel.
Bilko
Main scooter: LI150
I've had 2 different types of fuel hose.
Bilko's Oily Blog
Bilko
Main scooter: LI150
Cranks, bearings and seals changed.......
Still the same.
Bilko's Oily Blog
johnd
Main scooter: 1970 Dl125
When you ride someone else's scooter are the symptoms the same? Steel plate in the skull? East German pacemaker?
Bilko
Main scooter: LI150
HAHA! probably John.
Bilko's Oily Blog
