Series 2 Rebuild question - front mudguard
dapper
Never restored a fatty before but doing up a local lad's. Just about to start rebuild. Have brand new mudguard (not sprayed yet) but wanting to know how it fixes to legshields. I know about the three holes in the top for the horncast, but there are two lugs welded onto the inside of each side of the inside of the mudguard that I'm puzzled about. A photo would be very helpful if anyone has one.
WINTERMODEL150
Hi.there should be two brackets welded to the legshields with m5 threads..if you've not got these then the legshields are probably Spanish.
Dean
DigDug
Anything for you mate - you can just about make them out. :)
Did you have to do that?
dapper
Thanks John. Appreciate it. The legshields have those two brackets on them. But what connects the brackets to the muddy? Is it a long bolt that goes through the brackets or some sort of toggle connection :?: :shock:
belly
Main scooter: series 2 Li with TS1
Two long screws
DigDug
What Belly said - but basically whatever you can get in there Mark
dapper
Cheers me dears. I'll have a look when the leggies come back and see how they offer up wiv da muddy 8-) ;)
