blowing bulbs
sydduckett
Keep blowing front and back bulbs, start her up and lights come on fine rev her and they blow. I have tried two regulators that I know work and same thing happens. I have had a 12 volt battery on the loom and all lights are fine....Is there any way to check a stator to see if it's chucking out to much power while running? although I'm presuming the regulator would negate this? Also can you check the lightswitch whilst in situ? although again it must be chucking out 12v for the lights to work.....
Iv had the headset off and no obvious earthing issues. I know it could be a number of different things but I'd like to tackle them in the easiest order... :)
I fu%#*ng hate electrics :twisted:
thanks
Sef
essexgp
Main scooter: Indian Gp200 Indian Gp Cutdown
Is the speedo bulb ok as I seem to remember thats part of the regulation circuit, or then I again could be talking b*******s
Daggs
I would suspect a regulator fault.
sydduckett
changed the stator for one I know is kosher and the lights are now not blowing. On ramp at mo so will button her up and take her out after work tom. if alls good stator will be going back to dealer for replacement...
at last...... :D
rbgaz
Yeah and u scooter blew my volt reader !
Twinny
Main scooter: suzuki 185
syd bucket i will let you know when when i have buttond up your scoot and its off my ramp ,speak later :lol: :lol:
goldeneye
have you got a proper braided earth strap fitted between reg/engine/frame? another one between engine casing and frame is good also. my 2nd one is bolted onto the gear cable block, then onto the augusto , then the frame strut.cant have enough earths.
Daggs
If this thread is about a 12v electronic conversion (which is what i assumed) festooning your scooter with earth wires is totally unnecessary.
Sydduckett.
If the stator is producing a too high voltage? It's the job of the regulator to cut it back to 12V (ish)
Daggs wrote:If this thread is about a 12v electronic conversion (which is what i assumed) festooning your scooter with earth wires is totally unnecessary.
Sydduckett.
Sorry, are you saying that earths are unnecessary on 12v conversions??
The engine to frame one is vital, the DCI one is just a backup as it earths through the white wire to the stator.
    Users browsing this forum: Baidu [Spider] and 9 guests
