Gear selector shaft O ring leaking.
Any way of changing it with out taking the gearbox out.
Or any quality bodges.
longest of long shots
- bolzenanker
- registered user
- Main scooter: Spanish S2 Li150 1963
- Contact:
Used 2 O rings for the time being and seemed to work but is a bodge. Need to change selector and sleeve/bush next time I'm in there.
Ok stripped out the gearbox, rear hub off etc., etc.
pulled the spline out and lo and behold... Two O rings.
cant put my hand on sticky's book at the moment but Ive read on MBs that he has in the past used 3mm O rings.
Whats the proper fix?
- HxPaul
- registered user
- Main scooter: lambretta Li 150
- Contact:
You can use the thicker 3mm o-ring,but if the bush or selector shaft are badly worn they should be replaced.Jazzy wrote:Ok stripped out the gearbox, rear hub off etc., etc.
pulled the spline out and lo and behold... Two O rings.![]()
thanks,
Does the sleeve knock out with a drift? if I took one from another case, would it be re-usable?
found stickys book but cant find it shown
- HxPaul
- registered user
- Contact:
The bush has to be knocked out using a drift after the case is heated in that area.Using one thats been knocked out of another case is a bad idea because it wont necessarily be exactly the same size.Its always best to fit a new one.When you fit the bush it will need reaming to the right size.Jazzy wrote:thanks,
Thanks again,
Any literature available.
Jobs a good un.
Old Bush knocked out cold , New needed some heat.
Double shim on top of the wishbone keeping everything snug.
Thanks to scooterresterations for quick dispatch.
- Information
Who is online
Users browsing this forum: Amazon [Bot], Google [Bot], Google Adsense [Bot] and 4 guests
