BGM led rear brake light...
You can assume that .............. But why not touch the rear light power onto the brakle light connection and rule out the LED board?
- Doom Patrol
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
Steady on!
Timbo
- Main scooter: SX200 and GP230 RT
Daggs wrote:You can assume that .............. But why not touch the rear light power onto the brakle light connection and rule out the LED board?
Thanks, yes I did this and it lit up which made me think it was the switch but wanted a second opinion...
Now with the rear light connected normally, remove the two wires from the brake switch and touch them together (with engine running) If the brake light comes on. It's the switch. Ta-daTimbo wrote:Daggs wrote:You can assume that .............. But why not touch the rear light power onto the brakle light connection and rule out the LED board?
Thanks, yes I did this and it lit up which made me think it was the switch but wanted a second opinion.......not much to go wrong in the switch I guess, but it does look ok...
check the wires to the board.. i've had a couple of these rattle themselves to bits, the solder is a bit thin so had to carefully redo
