Cleaning / Sealing Fuel Tank
cartmel808
Who cleans and/or seals fuel tanks?..... Or is it something that's easy to do yoursel?
Got an old Vespa tank that I want to re-use on a project & it has residue in the bottom from being stood for 30 odd years with juice in - doesn't seem to have any rust inside though & is in really good nick other than the film of gunk in the bottom.
Tractorman
Main scooter: Lambretta li150 special
If you have no or little rust inside then you could try putting in some diesel and an hand full of nuts and bolts or ball bearing and keeping shaking it. Then keep changing the diesel until it comes out clean. You need to remove the tap, if vespa's have filter tubes or you'll damage it.
GLscoot
Main scooter: Vespa GS150
storkfoot
I've done this twice with good results:
http://www.realclassic.co.uk/techfiles/ ... moval.html
Tractorman
I have used this twice with excellent results but if you do not have any rust I don't think it's nescessary.
cartmel808
storkfoot wrote:I've done this twice with good results:
That sounds f@@kin terrifying!.... Disaster written all over it me thinks. Lol.
ducksta
i use a bit of chain with diesal comes up ok need a good flush after
cartmel808
Gonna try with diesel & some iron.... and if that doesn't work then I'll give the POR15 a try.
