Who cleans and/or seals fuel tanks?..... Or is it something that's easy to do yoursel?
Got an old Vespa tank that I want to re-use on a project & it has residue in the bottom from being stood for 30 odd years with juice in - doesn't seem to have any rust inside though & is in really good nick other than the film of gunk in the bottom.
Cleaning / Sealing Fuel Tank
cartmel808
- Main scooter: 1975 Vespa Rally 200 Femsa
Tractorman
- Main scooter: Lambretta li150 special
If you have no or little rust inside then you could try putting in some diesel and an hand full of nuts and bolts or ball bearing and keeping shaking it. Then keep changing the diesel until it comes out clean. You need to remove the tap, if vespa's have filter tubes or you'll damage it.
Tractorman
I have used this twice with excellent results but if you do not have any rust I don't think it's nescessary.GLscoot wrote:POR 15
http://www.holden.co.uk/displayproducts ... 7&pageno=4
cartmel808
That sounds f@@kin terrifying!.... Disaster written all over it me thinks. Lol.storkfoot wrote:I've done this twice with good results:
http://www.realclassic.co.uk/techfiles/ ... moval.html
i use a bit of chain with diesal comes up ok need a good flush after
cartmel808
Gonna try with diesel & some iron.... and if that doesn't work then I'll give the POR15 a try.
