My Pride & Joy
GLscoot
Main scooter: Vespa GS150
From this
ImageDSC_0224 by GLscoot, on Flickr
To this
ImageIMG_3678 by GLscoot, on Flickr
ImageIMG_3680 by GLscoot, on Flickr
Sunshine and hot tarmac, not good for stoping. Everything still works, going to cut the mudguard off, straighten the leg shield and use it for the remainder of the summer and fix it properly over the winter. Thats if the forks are ok.
Gary
scooter_italiano
Main scooter: Lambretta SX200
reading from this I was thinking about a restoration but seeing your scooter I was asking myself "why a restoration?! it's gorgeous!" but seeing to this :o
are you ok? did you ride it back home?
Yanker
Sorry to see that Gary, al least it is only the metal that got damaged and not you! Looks like the headset clamp might be snapped too?
ArmandTanzarian
That's a bugger. After all the time you spent on it too.
Lucky you have another 23 GSs to use as spares!
cartmel808
Oh No.... that's a sh**tter - sorry to see it like that Gary.... gutted for you mate. :(
GLscoot
i had to push the f@@ker home, uphill for about 100yds then free wheeled down to the house, it happened about 1/2 mile from my house. Sorted the headset and mudguard and my pal has taken it for a spin and says its ok apart from a noisy clutch. Tried sorting the leg shield, but ended up doing more damage than good.
I'm just so disappointed in myself, should have been able to avoid the car, although there was car on the other side of the road, so had to head towards the kerb. Slammed the rear brake and just glided towards it, knowing I was going to hit the car, so it was damage limitation. Still asking myself why I didn't use the front brake as well, but heh s**t happens and learn from your mistakes. I was able to walk away & the scooter will get fixed.
Gary
flipster
Kinnell .
Feel for u m8. Such a lovely scoot. I followed your thread on the build, brilliant.
Still as long as your ok, you've obviously got the know how to sort it so chin up eh.
Cheers.
P.N.D.S.C.
lambrusco
I was working in Bearsden today and the plumber said he seen this on the way to the job. He said it was a Volvo that was involved.
Hector.
cartmel808
lambrusco wrote:I was working in Bearsden today and the plumber said he seen this on the way to the job. He said it was a Volvo that was involved.
Hector.
It's always a f@@king Volvo! :roll:
ducksta
hope you ok m8, chin up and get stuck back into getting the scoot right as it may need a full rebuild if ou let everything else run down.
