Horrendous scraping when kicking over
Start stripping it down :(
This thread makes me wanna drive the 167 miles and have look myself..... sadly im not in burnely till next friday
vRSG60
Main scooter: Lambretta Li125 Lambretta GP20
Easiest bit 1st flywheel off nothing untoward there. Next step gearbox cover off but that'll have wait until tomorrow.
Out on the floor.
K.T.F.
I get my kicks out on the floor.
Grumpy225
Easy check.
Engage clutch and kick over. Does it lock?
While holding clutch in rotate flywheel. Does it lock?
Doing this separates the two ends of the motor and tells you were the problem is.
vRSG60
It doesn't bode well when bits like this come out of the exhaust now I've taken it off =
vRSG60
Grumpy225 wrote:Easy check.
No
Grumpy225 wrote: While holding clutch in rotate flywheel. Does it lock?
Yes.
that penny is in remarkedly good condition after its journey through your motor lol
vRSG60
Head off barrel off. Piston will not move beyond bottom dead centre. Bore and rings OK.
Gearbox casing off everything looks OK to me.
Sounds like it's coming down to the big end then.
When you say 'won't move beyond BDC' that you cannot rotate the crank beyond that point I.e. It will not turn in a full circle?
vRSG60
Yes won't turn full circle .
    Users browsing this forum: Amazon [Bot], Google [Bot] and 6 guests
