Spluttered. Won't rev
Bilko
Main scooter: LI150
Tried 2 floats John, both seemed fine.
Bilko's Oily Blog
blue
Have you tried fresh fuel?
Bilko
Main scooter: LI150
Hello mate, how's it going?
Haven't changed the petrol yet, but it's all I can think of trying so I'll give that a go.
Bilko's Oily Blog
wack 63
Main scooter: '71 GP TS1
What sort of carb is it?
Bilko
Main scooter: LI150
Two different 30mm dellortos.
I'm trying to ake a connection with why it happened so quickly. It had been running perfectly, crisp and clean. I start it up, second kick revs perfect then 50 yards on it dropped to a splutter in an instant and it hasn't run since. It tries to start and I get an occasional 2 send rev then it dies.
Bilko's Oily Blog
mick1
Main scooter: Li Avanti 225
Think a pressure test might be in order......could be seals or head......or quite a few other things :roll:
bazman
I'm thinking more of an electrical issue here possibly low tension coil. Even if you have acceptable readings on stator mate , they can still fail, what make is it ?
Worth banging a spare known good one on to try?
Bilko
Main scooter: LI150
Hope not Mick, but it's heading that way..
Baz, just talking with a mate at the minute about this and the spare stator will get thrown on next to see.
Bilko's Oily Blog
Mark ULC
Main scooter: LI Series 2
Bilko I too think it may the stator breaking down. Had the same issue earlier this year, it would start occasionally for a few seconds then cut straight out. Changed everything then finally the stator and sorted. I think the LT can read ok with meter but when running can drop away. I did notice the spark was poor before the new stator was it. Good luck.
Bilko
Main scooter: LI150
Hello Mark. How's it going?
I'll definitely be getting the spare stator on
Bilko's Oily Blog
    Users browsing this forum: Google [Bot], Semrush [Bot] and 6 guests
