connecting a battery charger to a loom to test eletrics
gaz_powell
Can someone be kind enough to remind me how to connect a battery charger to a loom as a temp supply to test lights etc.
From memory you remove the brown from the regular and connect positive then put negative to frame/earth
Gaz
Pepot
Main scooter: servetta LI150 serieIII GT186
I guess that if you want to test everything you must conect the positive to brown,pink and purple from the loom and negative to the frame.
JETEX
Depends on your wiring set up, but for say a straightforward AC electronic system, your post would be correct Gaz ( although I use an old car battery ).
essexgp
Main scooter: Indian Gp200 Indian Gp Cutdown
I use a battery charger myself as they usually have short circuit protection built in and will shut down rather than with a car battery possibly melting the loom if there is a low resistance problem :shock: :shock: :shock: (batterys are normally about 45amps)
nellyboyo
I use a small 12v power supply with over current protection
ducksta
and testing a vespa px black to? red to?
