GT 186
bazza3004
hi about to have my GT 186 kit bored out to 65.50mm and want to no if I will need to lift the reed with a packer and if so how thick should the packer be ?
Grumpy225
Those reeds sit pretty high relative to the cylinder wall, I wouldn't think you'd need a spacer plate. Of curse once it's been bored that might change things. I'd ask Rich and see what he has to say on it.
Rich_T
Main scooter: Li Special
It is only 0.75mm on diameter from stock bore, you should be fine I ran 66 without anything. I will make some laser cut packers at some point but remember that if you use a packer you will either need to use off centre engine mounts or manifolds that exit on the R/H side. With out these considerations the L/H side manifolds will contact the frame.
Rich T
bazza3004
Thanks for the replies , I already have the off set engine cones fitted rich but wont bother with the packer if as you say it isn't needed. cheers.
