Which drive sprocket?
lammer205
What drive sprocket is best on my scoot set up TS1 ,franspeed road, li150 box, and 46 crown wheel it was on af close ratio box but lost a tooth on the cluster so needs sorted soon, so what would you recommend 16/17/18/19? Thanxs Lammer205.
Your best bet is downloading Tony Cassidy's gearbox visualiser, it's brilliant, it lets you compared different set-ups.
viewtopic.php?f=7&t=28888
lammer205
Me, being a novice it would still be a guess(lots of numbers to look at on that) but a professional opinion would be great!! ;)
stokky
OK, here's what I do.
Use the "Lambretta Overall Gearbox Visualiser" from Beedspeed website.
http://beedspeed.com/html-pages/Lambret ... oChart.htm
That gives you final drive ratio's for any given gearbox and sprocket combination
Then I also use a chart off CAM LAM website that gives all sprocket combinations, and correct chain length to go with it.
http://www.lambretta.co.uk/downloads/gearbox.html
Also remember if you get a pull down chain tensioner gives a bit more flexibility on chain length
Finally the larger the front sprocket the less wear on your clutch
stokky
ok without all the charts etc.
My TS1 (bit tuned) I had at final drive 4.81 (pacemaker and 47-18 sprockets)
Good all round drive
phil23fair
Main scooter: Lambretta Li 250 Special
stokky wrote:ok without all the charts etc.
I've got the same setup and agree with Stokky
lammer205
Thanks lads,
As i have said above i need to use a 46 crownwheel(long story but this is my only option at this time) so it will have to be 46/?? to get me going any thoughts? thanx Lammer205
Muppet
exhaust?
C’est la vie
lammer205
Franspeed road mate.
joespeed
lammer205 wrote:Thanks lads,
16 poss 17
