H T lead
Copper with a suppressor cap. Silicon has a resistance which varies with length. Could result in a weak spark if used with a suppressor cap.
- tea5ive
- registered user
- Main scooter: cometa 140
- Contact:
currently using copper core but did not know if there was anything better as the same bit has been on for nearly 15 years , technology has not moved on in the H T lead world then
- Doom Patrol
- registered user
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
- Contact:
You're obviously not familiar with the new Quantum Discharge Unit in which the spark is invisibly relayed to the plug on a quantum level miraculously appearing in your spark plug and therefore doing away with the need for a physical connection of any kind.
Bluetooth for plugs ehDoom Patrol wrote:You're obviously not familiar with the new Quantum Discharge Unit in which the spark is invisibly relayed to the plug on a quantum level miraculously appearing in your spark plug and therefore doing away with the need for a physical connection of any kind.
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
have they solved that problem with QDU units yet?
Very occaisionally the "bluetooth" element in the system would lock on to other spark discharge systems ("SDS") resulting in misfires.
Has this been cured?
Scootering since 1968.
- tea5ive
- registered user
- Contact:
bristolmod wrote:Doom Patrol wrote:You're obviously not familiar with the new Quantum Discharge Unit in which the spark is invisibly relayed to the plug on a quantum level miraculously appearing in your spark plug and therefore doing away with the need for a physical connection of any kind.
i think i am going back to point's, condensor and coil
- Information
Who is online
Users browsing this forum: Google [Bot], Majestic-12 [Bot], Semrush [Bot] and 11 guests
