Choking/4-stroking through the gears
hat
Main scooter: SX150/ Mugello 186
Running a PX125, kitted with Pinasco 177 & Sip road 2. Has been dynoed and set up by Dan around 9 months ago. Its running fine except for the fact that when going up through the gears its 4-stroking. Its not excessive but it doesnt feel to accelerate as cleanly as it could, its the same thing you get when setting off from cold but it doesnt clear when its warmed up. Its had several tanks of fuel from different garages. I havent changed anything since the dyno so im stumped to understand why this has started happening
Jack221
Main scooter: PX221
The needles and atomisers wear bigger as you use them. It could be that if the jetting was a little rich it wont take much needle wear to go slightly over. New atomiser and needle the same numbers as before or same needle and atomiser 1 size smaller should do it.
also check that the choke is shutting off properly and that the air filter is not dirty
hat
Plug was dirty so ive swapped it out and there was a bit of dirt on the jet stack so ill see if that improves things. Choke is fine and air filter is spotless
Norrie Bodge
Read this thread will help you http://scooterotica.org/forum/viewtopic.php?f=8&t=27378
Run my malossi 210 using a BE2 atomiser as was doing same thing, no probs since ;-)
Jack221
Main scooter: PX221
Lets try again ;) What main jet do you have in?
