AIR HOSE TO FIT OVER PHBH BELLMOUTH
Agent Buchwald
I have tried various filter set ups including massive oval ram airs straight onto the carb and on the end of carb bellows without much success - alright but with compromises in top end or driveability. Probably a sign of getting old but I'd swap quite a lot of top end for an engine that'll tick over and drive from low down and pull through the rev range - maybe some sort of still air box will help.
storkfoot
Is this what you are after?
http://lambretta.co.uk/catalog/product_ ... ts_id=3178
CamLam are out of stock but you may find one of the German shops has them.
Agent Buchwald
Thanks - that is what I'm after but without the filter - i think corrado, justlambretta has got one so should be fine now, cheers.
I've made it fit the standard elbow too. It's too neat to call it a bodge. 8-)
You can also buy a short, thin aluminium screw on bellmouth that is perfect for fitting the breathsweet elbows to, got mine on ebay 8-)
Timbo
Is your breath sweet squashed a little? Mime is and according to the dyno man is restricting the bhp by 3. Any tips? I will try a shorter manifold when I get back from a ride to a France on Monday. I have a 11.5 litre tank so space is restricted.
    Users browsing this forum: Baidu [Spider], Google [Bot] and 12 guests
