Run in Period
Strummer10
Main scooter: Lambretta LI Special 225
Guys.........what's the suggested 'take it easy run in period' IF you have rebuilt a lammy engine with new bearings and seals and put new piston rings in. Its a GP 200 stage 4 conventional steel barrell engine by the way
ForemanBob
Main scooter: GP RT230
The motocross guys would tell you to get your bike up to full temperature and then let it cool down fully to cold, and do this twice.
I like to do this and for rings take it easy for 100 miles or so.
ForemanBob wrote:The motocross guys would tell you to get your bike up to full temperature and then let it cool down fully to cold, and do this twice.
I'd go with the same, around a 100 miles or so to bed everything in but vary the speed interspersing some short blasts which will help the rings bed in (so I'm told).
I think the motocross advice probably relates to ceramic or Nicasyl plated bores rather than bottom ends though :?
storkfoot
:shock: Unless I was certain that the piston to bore clearance was, say, 4 thou. of an inch (that's about 0.9mm) I'd do a hell of a lot longer than that on an iron barrel. The manual said 1000 miles for a reason. But the way you run it in is the really important issue.
Nicasil/alloy barrels are a different case entirely.
storkfoot wrote::shock: Unless I was certain that the piston to bore clearance was, say, 4 thou. of an inch (that's about 0.9mm) I'd do a hell of a lot longer than that on an iron barrel. The manual said 1000 miles for a reason. But the way you run it in is the really important issue.
He only changed the rings Paul, no mention of a new bore or piston otherwise I would agree ;)
Donnie
then theres the new bearings and seals to contend with too.
So it's effectively had a complete strip and rebuild with new rings too.
Personally if it was a new top end too i always say the 1000 mile rule, if though as above its only had bearings seals and rings then I would say 100 miles for the rings doing the usual building up speeds for the first 50, then short! bursts of speed intermittently for the next 50 while all the time increasing that top speed.
additionally at 250 miles I would do a gear oil change to remove any bits produced from the bearings bedding in, but that's just me.
Donnie.
storkfoot
Whoops. So he did
monument7
Main scooter: Li auto conversion 180
Unless I was certain that the piston to bore clearance was, say, 4 thou. of an inch (that's about 0.9mm) .
4 thou is 0.1mm
storkfoot
Of course. I think I can safely say that my input was less than useful on this thread. Will try harder next time ;-)
Timbo
500 minimum to 1000......that would take Traindriver about 3 years..... :lol:
    Users browsing this forum: Google Adsense [Bot] and 8 guests
