fastfrog
Yes i can't wait to see it on its wheels... looks like a thousands weeks away....
Size matters!
Snapper
Main scooter: Vespa T5 Classic
Chin up, mon ami...you'll be flying in no time I'm sure! ;)
fastfrog
Thank God, my T5 works as a missile.....
Size matters!
fastfrog
TDC and from U to D: 22,20,18 16°
Size matters!
fastfrog
engine is almost finished. i'm only waiting for this blo.dy pipe design "torque s-box"...
Meanwhile frame is having its first mat back (RAL 9017) painting on:
As you can see this lince is in fact an exclusive 80 bitza, probably build in the last exclusive series begining its lince turning in....
20 years ahead isn't it?
Size matters!
fastfrog
new items arrived:
rubber manifold dellorto shorter than the one sold by stage6
ramair and evergreen: With an 60mm ext tube for junction it' ll be stiffer (evergreen is very soft) and sealed:
And now the big issue: I guess the whole air duction system is larger than what side panel leaves :| Somebody knows the space between engine mounting and panel??
Size matters!
That's great info about the shorter rubber manifold mount, thanks. Where did you buy yours from?
Anyone know who might sell them in the UK?
fastfrog
http://www.stein-dinse.com ref 10577-82
Ach! direkt von Deutschland!
Size matters!
fastfrog
tool box panel dremelized:
it needs still a little smooth but it's close to what I wanted.
Size matters!
fastfrog wrote:http://www.stein-dinse.com ref 10577-82
Thanks for the link.
    Users browsing this forum: Google [Bot] and 14 guests
