Gp lights
newboy
12v elec ign with vespa cdi. I've 100% got power coming the stator tested it with a bulb. It's got a brown wire carrying the power up to the headset. I read on af if I plug my wire with soldered bulb on the end into where the brown goes on the reggy an earth it the bulb should light ? I did this an have no light, so from what I can gather the reggys f@@ked ?
joespeed
check the bulb on a known supply (car battery) try again,
newboy
Bulb works off the stator
mick1
Main scooter: Li Avanti 225
So you have voltage going in the regulator but not coming out of it ?
newboy
Yea m8
Sounds like the regs popped then. Swap it with a known good one is the best way forward.
