Gp lights
newboy
On way back from mot, lost all lights. Was working fine until then. Changed stator cuz I had one spare, lost the horn aswell. Any ideas ? Cheers
Wire popped out somewhere?
mick1
Main scooter: Li Avanti 225
+1 on the loose wire/connection. After that i'd look at the regulator.
newboy
What colours the power cable coming out the loom into the headset?
mick1
browns a good bet ....invest in Stickeys manual it's got all the common diagrams
newboy
Got no power coming up from the brown
mick1
the brown should be at the regulator. have you power there ?
newboy
Tested the stator by welding a piece of wire onto a bulb an we have light at the stator? What's next to try ?
newboy
Following the steps on af it's pointing towards a regulator ?
You've not said what kind of stator you have and how it's wired. I think we're presuming it's an electronic kit with a vespa type regulator. If so then is is wired for AC or DC? If AC then you'll have a wire that goes to the reg from the stator, usually yellow. If you have power on that wire then you need to identify the terminal that takes the regulated power out of the reg to the loom, often a red and it should also have an earth.
Now depending on what loom you have standard or simplified ? You may have one or more wires connected together to carry that power up to the headseat. There may or may not be a junction box, check the connections there.
A standard loom will usually have a brown and a purple carrying power.
    Users browsing this forum: Semrush [Bot] and 67 guests
