Re: 12V DC CONVERSION - HOW TO
dapper
Yes, sorry Mike, that's what I meant. So I connect a piggy back terminal to the positive on the battery to go to the cigar socket and the other connection from the cigar socket to earth? Yes?
Yeah, but don't forget to put a fuse on the earth side ;)
dapper
Already got a fuse from battery -neg term to earth. Do I need another fuse for the cigar socket to earth as well??
victor
Main scooter: Tv175 but currently a SS210 :)
Only had time to look through the first 5 pages or so of this conversation, so apologise if it's discussed somewhere else, but have one question.
This requires re-soldering the stator (easy enough) to, what I suppose is, connect the two coils in series to double the outputted voltage (at the expense of the amp dropping).
Practically, how does this differ from the lcgb solution (http://www.ilambretta.com/12v.html) that only requires you to connect the brown output to the rectifier and then hooking that up to the loom and battery? Or does it at all?
Donnie
The easy version on the lcgb site is a) on a points 6v stator, this thread is talking about electronic ignition
additionally the dc stator conversion gives true direct current 12v
Donnie.
MathPOP
Hello,
I need to Update my Vespa S 50 (2 Stroke) in Full Wave conversion :D
Normally my vespa Use the same Stator 6 Poles (with some differences)
... I have contact BGM for the best way to realise this conversion. So... Now i have the new Full DC Regulator / Rectifier 12V DC Wassell/PODtronic
Like this
i have a little problem
1- For update my stator in Full wave DC i need to add the new yellow wire... OK
But my stator have a Blue and grey wire more (see the picture)
Normally in need only this wires for full wave DC: 2 yellow + Red + White + Black?
Thank you for your HELP :roll:
terryokey
Main scooter: Lambretta SX150
Doing a dc convertion on ac scooter only need to change the horn, fitted are BMG dc stator and BMG Rectifier . i dont need to change the wiring loom on scooter or ignition
Donnie
I don't know if that's a question or a statement?
But if a question, no you don't need to change the loom but you may need to adjust the wiring, best to follow the instructions at the start. All teh informations there.
Donnie.
I've got a few UK rewired Indian stators to work DC with Wassell regulator. £77 for stator and regulator + P&P. PM for details.
MathPOP wrote: Thank you for your HELP :roll:
It doesn't help that there is only half a wiring diagram in your post :roll: Also, it seems to be for a scoot already with a battery :? I*n order to convert to FULL DC the 4 lighting coils on the stator need to be wired in series with one yellow soldered to either end. Those wires connect to the Wassel unit input and the black Wassel wire goes to earth and the red connectes to the lighting feed connection into the loom. With a purely AC scooter, that is all that is necessary unless a battery is being added but in your case there will be some more changes to the loom necessary but unless you post up a FULL diagram, no one can help you.
