Lambrettas as we all know have for many years used many different conrod and pistons .
Who knows of any large frame motors that use exotic rods and pistons ?
Theres always Mr Broadhursts Suzuki/Rotax kit but what other rods could we fit ?
Not just 200 cases but 125/150 also .
Large frame conrod conversions ?
gaz_powell
Suzuki gt 750 piston was used in p2 225 conversions - it was the left hand piston that was used I think
I've done a suzuki ts185 piston in a t5 polini barrel
Never messed about with rods on vespa
grimspeed
- Main scooter: gp 283 kx
That's right . left hand piston and a rotax rod !
Im just trying to open up some options here and pick peoples brains and experience .
Like could I use a RD400 rod on a P2 crank ?
Kingwelle
- Main scooter: GS2 GS3 Rally200 Primavera et
What kind of conrod you are looking for?
Just one sample of customized crankshafts with an 110 mm, 125 mm and a 143 mm conrod for large frames
https://m.facebook.com/kingwellen/photo ... &source=46
Ginch
- Main scooter: Vespa 150 Super
This is an interesting read on the subject - http://www.scootercentral.net/forums/vi ... &t=15818&h with some thoughts on the effect of a longer rod on case volume/compression.
grimspeed
My perfect crank would be a 57mm p2 bell shaped crank with a 115mm or 116 mm conrod. Im putting a gilera runner 172 kit on a px 125 case using a 13 mm spacer with the transfers cut in it !
