Worm Drive
LI150
Main scooter: Series 2 LI150
Before I go and start purchasing new parts can anyone shed any light as to why my drive used to mesh correctly and now since the hub has been painted and refurbed with new seals and bearings it doesn't.
LI150
No one :cry:
DaveTomo
Main scooter: SX 200
Is it metal or plastic? if its metal try lapping it with grinding paste.Had the same on a drum brake I had,after painting , new seals bearing etc, would turn so far then lock.Bit of grinding paste to bed it back in & was spot on,my only thoughts at the time was that changing all the bearings, new paint etc, had altered the tolerances a bit, just enough to stop it working.
Quote off the MB site
"When fitting these new speedo drives sometimes they may need lapping in with grinding paste, this is because there are so many differences in machined hubs.
Occasionally the speedo drive pinion may need some modification or a washer fitting first, this again is because there are so many different hubs all been machined different. "
http://lambrettaspares.com/spares/front ... 0088s.html
LI150
Cheers for reply its metal and the problem is it doesn't mate together and slips. Will try the washer method. :D
