Lambretta Series 2 with Megasquirt EFI and 180w Igntion Syst
Rich_T
Main scooter: Li Special
At the moment the current BoM indicates a retail in the region of £900. This is everything, ECU, Throttle bodies, pump, injector, sub tank (I use the SV650 fuel pump because it is much neater for the plumbing but does require a sub tank). It does require that the scooter is already converted to RS125 ignition.
TED CRUD
Top Notch Rich ,well done looking forward to seeing more !!!
Smash Ya Pastie
Washington Posse s.c
The German MMW EFI is now running...
http://www.youtube.com/watch?v=_VrfWBkTqtc
http://www.youtube.com/watch?v=_DKymUApHkU
I don't know the costs yet.
Stampede
Main scooter: SX200
He doesn´t plan to get in a series production yet, it´s just for him.
gravedigger
the new serveta EFIproject
gravedigger
dansacred
Main scooter: li 150 series 3
early power is massive
WINTERMODEL150
Rich_T wrote:At the moment the current BoM indicates a retail in thhow is region of £900. This is everything, ECU, Throtit's everythingump, injector, sub tank (I use the SV650 fuel pump because it is much neater for the plumbing but does ruel tank). It does require that the scooter is already converted to RS125 ignition.
Hi Rich.what sort of fuel pressure would you estimate these to run at?how is the cold start enrichment device worked out if its air cooled?is there a sensor under spark plug or in exhaust?do you run a stepper motor for the idle or just a cable effect?.
Regards
Dean
gravedigger
dansacred wrote:early power is massive
that's the torque curve.
Yanker
TED CRUD wrote:Mint i knew things like this have been about fitted to Ossa trials bikes but its the first time i have seen it on a Lammy
Noticed that too. Like the multi-point injection logic. The LC 300cc top end and injection system looks ripe for transplant to me :D
