Any ts1 tips please
simonwwfc
Looking at a scoot tomorrow with a ts1 engine spec from owner is
Mb 220 bored out to 225 30mil dellorto running a original taffspeed mk4 chromed pipe diablo long range tank hydro disc all in tv200 casing year is a 76 all seals and bearings replaced with new af race crank bout 180 miles ago
Anything to look out for cheers
220 bored out to 225 is not correct, more likely 200 to 225, ask for receipts for Mb work
Sent from my GT-I9300 using Tapatalk
10 inch Terror
Xbox live gamer tag: No.
Have you got a mate who knows his way around a scooter? if you have, take him with you to give it a good inspection. The seller may be a 100% genuine guy, but there are some scammers about. as Andy said, that engine spec sounds wrong. Good luck whatever you decide to do.
I'd be very sceptical if someone told me it was a TS1 bored out to 225.
TS1 200cc mustn't have been around for at least 8 years or more, so even if it is a 200 bored to 225 and replated [ or lined] it's still an old kit.
GP Kevo
My old TS1 200 is now a 230 at 71 mm bore. Once this has worn out I should have saved enough for a Super Monza.
Special X
Could it be one of Mr B's steel liner TS1s that's been rebored?
There'll be a number engraved on the bottom of it. Armed with that, you can ask the tuner what it is. They'll have it written down.
It's all a bit late, Simon's probably looked at another 20 by now.
    Users browsing this forum: Baidu [Spider] and 6 guests
