Best clutch ?
DigDug
The LTH:
Did you have to do that?
10 inch Terror wrote:It all depends on your engine spec. There's no need to spend more than £100 on anything under 20BHP in my opinion. You can get a Readspeed 5 plate kit for £50 and you can still use all your other standard clutch parts. I'd swap over the supplied springs for MB ones (personal preference) and you'll have a lovely light clutch for very little money. Add the cost of a new clutch cable, oil and chain case gasket and you'll have change from £100. Why over egg the pudding when there's no need to?
Agree. It's all relative. Spend accordingly.
There's no need for Porsches or Aston Martins but they're out there.
DigDug
corrado wrote:There's no need for Porsches but they're out there.
There is if you want a two seater with a shed load of luggage space that's quite fast, reliable and handles like a go-kart. ;)
10 inch Terror
Xbox live gamer tag: No.
corrado wrote:There's no need for Porsches or Aston Martins but they're out there.
So, if you needed a little runaround to take the wife shopping once a week, you'd buy an Aston or Porsche? My point is, buy what suits your needs, not your desires. Yes an LTH clutch is a lovely thing, but in a bog standard LI150, it would be a total overkill, but in a 30HP motor, it would be perfect.
DigDug wrote:The LTH:
looks good, but I do hate fitting that clip thing when rebuilding vespa clutches...
DigDug
Just get Dan to do them.... ;)
DigDug
Depends on how much disposable you have - that's exactly what a good many expensive motors are bought for. :shock:
poppygun
Playstation gamer tag: poppygun
Main scooter: GP200 1969
hi all thanks for all the replies have gone and bought a mmw / lth 7 plate clutch i think they are the same clutch?
But i have two questions 1 do i need to soak plates as they are not cork ? 2 do i have to use old circlip on this clutch as one not supplied
regards poppygun
    Users browsing this forum: Amazon [Bot], Semrush [Bot] and 7 guests
