Imola v Muggelo ?
simonwwfc
I'm looking at poss fittment off one or other now is the extra money with it for the imola . Is the imola more bullet proof , would it run ok for temp time with a sterling pipe and 28 or 30 dellorto carb , until funds are available for a better pipe .
speedy
Both are totally different kits,so be sure what you're actually looking for before choosing a kit. The Imola will run fine on a 30mm carb if that helps.Cheers,Speedy.
Minority
Main scooter: Li230 S3
"Bullet proof", well there's more to go wrong with the imola and you will have to thrash it harder (sorry that should read rev it harder :lol: ) so probably not.
tonydevon
Main scooter: '71 GP125
I ran the mugello 198 kit, worked better with 26mm dellorto, had a PM tuning expansion, that also seemed to suit it
it was quick enough and did what I wanted.
the imola kit doesnt seem that much more money, but the added advantages of reedvalve could well be covered by the small cost.
I dont regret buying the mugello, but did wonder about getting a LTH reedvalve etc a few times.
Nothing is bullet proof and nothing is a major problem if set up correctly.
You could throw the MBBGM kit into the mix too. Similar to the Mugello but with a better head that should improve cooling.
As Speedy says they're suited to different styles. For me, if you ride a lot on your own then I'd opt for the Imola but if riding with Sunday selection box Egg run types then the MB kit would be more suitable.
Sterling / scootrs pipe worked well on my Imola.
corrado wrote:...Sunday selection box Egg run types...
:lol:
Bifter
Main scooter: vespa p210
How does a casa compare to these kits ?
sydduckett
Slower.... :D
simonwwfc
Who's doing good deals on theses kits at moment best price is £550 plus post for imola
Would have thought they'll all be much of a muchness. There's a limited number of outlets.
