hi,my lambretta gp 175 starts 2nd kick from cold,no problem,runs great then when its switched off and left for a few minuets it wont start again,stinks of petrol like its flooded,happened this morning ,had to sit and wait 20mins in the p1551ing rain,then the f---er went again,im switching the tap off and the fuel cap is breathing ok,
any sugestions welcome, brian.
wont start when hot ?
bristolmod
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
when it won't start when its hot, do you have a spark anyway?
If yes, then its probably carb or rings or seals
If No- then its probably ignition side.
When it happens next time check out the spark and report back on here please
Scootering since 1968.
bristolmod
OK
carb- what carb is on there? jet / slide/ atomiser etc sizes etc
shouldn't really happen on a new carb (jettex) but.
check if the plastic float is moving properly, they have a tendency to rub on the side of the bowl or jam on the swivel pin.
Two likelyhoods.
One you are screwing the throttle open on hot starts, causing flooding.
Or the pilot jet is oversized. Jetex will work with a 42, 43, 45 or even a 48. You need to find out which is best.
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 1 guest
