fork height
nige65
Main scooter: lambretta series 2
got a series 4 li non chrome ring got a set of forks for it but seem tobe 8-10 mm to short bolt for headset clamp does not line up and top of horncasting is rubbing on bottom of headset ...
FATBLOKE
Sounds like you got Spanish forks is the stem length 460? Should be 467 despite other guides stating differently. Are the forks ones with clip in rubbers?
nige65
rubbers same as late sx and gp type
FATBLOKE
Stem length 467? from where bearing seats to end of stem?
