Be gentle
peter357bikes
I have both and the outboard from corrado wins easily....................
YAMLAM
scoot rs antidive all day long.
win or lose have a booze
I hope Randall is reading this. He always reckons he doesn't get a fair press. :lol:
Doom Patrol wrote:I hope Randall is reading this. He always reckons he doesn't get a fair press. :lol:
In the interests of balance then..
I've had a Saigon Scooter Center one for seven or eight years. Fantastic bit of kit. If I was buying another one, I'd probably go with one of the double Mito ones, for the few extra bucks they cost.
10 inch Terror
Xbox live gamer tag: No.
A reverse pull drum brake better than my LTH anti dive? No no no!
phil23fair
Main scooter: Lambretta Li 250 Special
corrado wrote:apart from drilling your headset to accommodate the hydraulic hose.
You don't necessarily need to drill your headset for the hydraulic hose. If you thin down your throttle control rod and drill the hydraulic master cylinder mounting that comes with the disc brake you can thread a longer than standard hydraulic hose through the headset in the same route a cable would go. I have just done this on a scooter I am rebuilding.
slangen
Main scooter: TV200
Interesting lets see a picture please...
Herman
Main scooter: GP200
I can only remember using the front brake once on a scooter, on my way to my test in about 84. Thought I'd practice my emergency stop, locked up the front wheel and went a pisser. Have avoided using the right hand lever ever since
Autobahn
Herman wrote:I can only remember using the front brake once on a scooter, on my way to my test in about 84. Thought I'd practice my emergency stop, locked up the front wheel and went a pisser. Have avoided using the right hand lever ever since
That's a very brave admission. Does anyone you ride with know?
joespeed
the rear brake is for the mot only,an ornament!
the last mot i did the adjuster had fallen off the rear brake!
you must ride as fast as my mrs pushes the shopping trolley round the super market!lol
