Yanker
Nice Tune Grenouille.
Port timings on the final spec?
Someone please tell me that Lince's dampers ar wrongly oriented?
Bon Soir, de a grnoouille qui fait
fastfrog
Thanks folks. try not to burp doing my tuning!
Big deal to symetrize both mains. Left transfert has a more tapered roof and is narrower than its brother. A pain to do it nice and straight without vinamold... I'm trying to dig hooks front and rear but one of the studs's passing so close I'm afraid to go thru the metal...
I can't wait to get the new piston and have a complete view of the peg spot to dig 2 or 3 boost ports. Depends of the room left by the 2 ring pegs...
Size matters!
fastfrog
Yanker
port timing with a 60mm stroke crank, lth reed block, 30mm Dello:
E:175-180°
T:125°
BD: 25-27,5°
As a matter of fact a good timing setup for a "tourisme rapide" lammy: a two face baby with lots of torque from bottom end till 5000 and a blast of civilized power from 6 to 7500 rpm. red line after 8500.
I'll get a pipe design S-box still in developpment by now. Marco Renztmann, the boss, knows my tuning extravaganza and probably will launch one of his new babies for me.
Size matters!
They look right enough to me
fastfrog
another pic:
Size matters!
fastfrog
I received my new mb head, piston and lth reed manifold.
head is a nice piece of work:
Forged piston with wiseco rings: nice piece too:
lth manifold: good but loosy:
casting and fitting: fine, you almost don't need to cut fins. But rubber manifold is a crappy loosy (just 2 bolts) item which doesn't match the reed block. Sealing it will be a pain. I've read lots of comments telling about air leaks issues... I'll think about it. Maybe doing an in-between-plate to inlarge both sealing surface.
from inside: needs a porting:
Size matters!
fastfrog
almost finished: passed and flowed
Size matters!
fastfrog
manifold out:
Size matters!
fastfrog
The 2 boost ports will settle somewhere between those 2 black lines (figuring peg runs) and center by the black mark.
Size matters!
fastfrog
Aint no time tonight for grinding (hum hum...) but i've done my plans for tomorrow:
Size matters!
    Users browsing this forum: Google [Bot] and 29 guests
