PX200 Standard Piaggio barrel - 27.75 bhp
Post your Vespa dyno graphs here! But graphs & spec info only, keep the chat in the 'dyno chat' section ;o)
MattsDad
200 barrel, not the BGM one. Standard barrel, piston and head; jacked up a bit, skimmed and ported, no welding.
JL pipe, flatslide carb, variable ignition.
Just done for a bit of fun!
COCKSPEED TUNING
ArmandTanzarian
If I'm reading that right then it must be nigh on unrideable. It has less power than a standard factory P2 until it reaches more than 6000rpm.
mick1
Main scooter: Li Avanti 225
Impressive :shock:
What type of variable ignition ? (is it mapped ?)
Have I read that right Tony? Standard thick-cast rings revving to nearly 9000 rpm? Maybe I've misunderstood?
MattsDad
Yes. Previous Pinasco tune rings the same.
COCKSPEED TUNING
MattsDad
ArmandTanzarian wrote:If I'm reading that right then it must be nigh on unrideable. It has less power than a standard factory P2 until it reaches more than 6000rpm.
Its likely the landscape of the graph, factory would peak circa 9 at around 6k from experience of friends who have dynoed.
COCKSPEED TUNING
johnny rotten
Main scooter: px200e
Is it a HB stage 4 too end?
Muppet
johnny rotten wrote:Is it a HB stage 4 too end?
ifin it was id expect a flatter powerband
C’est la vie
MattsDad
:) No it is not a HB.
It does rev on a bit more as well Dan, I didn't put it up but we tried a race pipe also, one which I thought would suit best but it is for a different engine and it lost some power:
COCKSPEED TUNING
225worb
Main scooter: Vespa 225, Falc , 230 S2
F##k me .....must be a reeet monster to ride....
Ive got a reed 225 malossi tuned blah blah and that's only knocking out 26.5 hp....
love to see/ride it ....is it rideable ???
