Anyone running a SSC taffy copy pipe?
simonwwfc
Any pics of rear mod bracket please
johnd
Main scooter: 1970 Dl125
Its a really well made pipe, but the rear bracket is a bit cheap looking, i also didn't get any long bolts for thew bracket with mine, i suppose i'll have to buy some.
My stand is a brand new italian stand and it is quite narrow on the kickstart side, i'll have to take it off, heat it up and bend it.
johnd
slangen wrote:Does this thing clear rear footboard on a series 3???
It looks like a small amount of the footboard will need to be removed for a safe fit.
simonwwfc
Any spacer ? With pipe or have u gotta buy them . Also wot size bolts did u buy
simonwwfc
Wonder if the pipe can be polished or chromed
simonwwfc
rosscla wrote:You can buy it in shiny...
http://scooterotica.net/userimages/procart11.htm
Can't none in stock ;) ....... 6 to 8 week wait on the boat
gaz_powell
I had my first one chromed by trev harrison - no problems at all.
All the welds were polished out to no detriment.
I use extended studs in the casing and not bolts
I have had no fitting or in use problems with both the mild steel chromed one or stainless one
simonwwfc
Looks pukka
    Users browsing this forum: Google [Bot] and 66 guests
