Anyone running a SSC taffy copy pipe?
johnd
Main scooter: 1970 Dl125
Could you take and post a pic of how you have the rear bracket set up? I want to make sure i fit it correctly. :oops:
johnd
And does your centre stand foul on it like mine?
gaz_powell
i`m in the garage tomorrow so i get a picture
i have 3 they all catch the stand to varying degree when i fitted them
one required just a shave of the stand foot and the the othes a bend on the stand but not much
gaz
johnd
I think the stand needs a bend alright, cheers in advance for the pic!
gaz_powell
john
pm your email and I`ll fwd the close up pictures if you still need them
they are not great as the brackets are coated black but you should get the gist
gaz
simonwwfc
simonwwfc
Had one on my old gp the only issue I had was crappy tail can mecarno bracket that I took to work and modified myself plus bought a bracket from scooter loopy john
simonwwfc
Just bought another one today from dan
slangen
Main scooter: TV200
Does this thing clear rear footboard on a series 3???
gaz_powell
the most recent one I fitted a stainless one to a full panelled gp - I only had to take a scoop out the back of the runner (as most expansion pipes)
funnily enough that one never fouled the stand
regarding the rear bracket I alter them and add a rubber bobbin - done loads of miles on a stainless and mild steel one
good pipes
