Polini longstroke 221cc top end
bazman
Hi , has anyone bought this along with a 60mm crank, if so feedback please, have a mate who wants me to build a tourer engine , cheers :)
johnny rotten
Main scooter: px200e
Try Harry Barlow mate I believe he does a set up using a 60mm crank n Polini topend
bazman
Sorry it's the actual off the shelf polini kit to suit the 60mm crank plug and play as it were !
Jack221
Main scooter: PX221
I think the Polini 207 with 60mm crank is just about the perfect touring set up. If you put the 1.5 mm packer on the base gasket and adjust with a few extra thin gaskets to get the piston sitting 0.5mm from the top of the barrel, then the porting is a bit longer on the transfers and it will rev a little more. Or you can set it up with the piston about 0.5mm out the top of the barrel with a deep head, if you are planning to upgear the primary.
Vespa est ieiunas, quia semper operaturi
H,POOL GADGE
i'll tell ye exactly how the 220 polini performs...my spec is - alloy polini 210 barrel, casings matched, pinasco re-profiled 10-1 head, 1.4 squish? i think, 1.5 packer, pinasco 60mm crank+inlet duration worked, 24/24 carb+carb inlet worked, main 128, Be3, 140 air corrector, 48/100 idle, standard 4th gear, jL r/hander, dyno'ed at 19bhp/17torque...i personally asked sean/dan for a tourer and thats exactly what this engine does! it's a low revving thumper and pulls and pulls, i personally cruise 60gps uphill/downhill and in headwind @ 1/3 - 1/2 throttle 120-140mle to the tank, i have gps'd scoot at 70 then backed it off, not really wot i'm about now! the polini will never be a malossi. malossi's a very quick of the mark but fade and thirsty, this polini tune is subtle of the mark and a thumping pulling machine with economy, a very happy owld man me!!!! :D
bazman
Thanks lads , sounds a goer, Polini after they brought out the alloy 210 kit , made one with a head i'm led to believe specifically for the 60mm crank. No packers needed etc.
Must be pretty thin on the ground as looks like everyone out of stock.
H,POOL GADGE
Contact wasp performance, he'll get ye one,,,
bazman
Will do Gadge , ordered stuff from him last week for a rebuild , very happy and saved the lad over £30 over what Allstyles were charging . :D
This is what I was looking at ..
http://www.scooter-center.com/product/P ... 00?lang=en
H,POOL GADGE
Wasp supplied all the gear for my build and he mentioned the new polini kit was coming out, that was about 4 month a go, so maybe if anyone can get it he will. He's a good lad wasp!!!!
bazman
Been in touch already mate , was supposed to be out 2 months ago but you know what these bloody scooter manafacturer's are like!!!
No sign of the bgm pipe either ffs !!!
