warped malossi piston - why?
markauk
working on a pal's PX125 with a 166 Malossi
what would cause the piston to warp like this? its exhaust side damage
goldeneye
alreet mark, hows it going? that looks a canny one! whats that stuck on the exhaust side of the piston? looks like something has been sucked in, or a ring has spun, snagged in the exhaust port, and forced the piston crown up. its been running hot as well by the looks of it.
Jack221
Main scooter: PX221
At least there is no sign of pinking :roll: That certainly is a bad one. Barrel ok?
In the first picture before the crown was cleaned it looks like its running really very lean. The plug must have been grey.
Vespa est ieiunas, quia semper operaturi
Has the exhaust port been tuned, with a wider port?
Polossi220
Main scooter: Vespa PX220
Similar to one I just had revolver down pipe had cracked destroyed /melted exhaust side of piston
Very nasty, got a picture of the cylinder ???
Was the exhaust blocked causing the port shaped stain?
markauk
the exhaust wasn't on very tightly at the barrel, would air intake cause this?
Jack221
Main scooter: PX221
If it was running weak anyway then, yes! A loose exhaust will make it run even weaker
