warped malossi piston - why?
markauk
working on a pal's PX125 with a 166 Malossi
what would cause the piston to warp like this? its exhaust side damage
goldeneye
alreet mark, hows it going? that looks a canny one! whats that stuck on the exhaust side of the piston? looks like something has been sucked in, or a ring has spun, snagged in the exhaust port, and forced the piston crown up. its been running hot as well by the looks of it.
Jack221
Main scooter: PX221
At least there is no sign of pinking :roll: That certainly is a bad one. Barrel ok?
In the first picture before the crown was cleaned it looks like its running really very lean. The plug must have been grey.
Adam_Winstone
Has the exhaust port been tuned, with a wider port?
Polossi220
Main scooter: Vespa PX220
Similar to one I just had revolver down pipe had cracked destroyed /melted exhaust side of piston
Very nasty, got a picture of the cylinder ???
wack 63
Main scooter: '71 GP TS1
Was the exhaust blocked causing the port shaped stain?
markauk
the exhaust wasn't on very tightly at the barrel, would air intake cause this?
Jack221
Main scooter: PX221
If it was running weak anyway then, yes! A loose exhaust will make it run even weaker
