Badge adhesive
sydduckett
Have a new lambretta badge for my legshields but the tines are quite short and with the amount of filler in them I'm unlikely to be able to preen them back. Anyone know where you can get ones with longer tines or recommend an adhesive/glue that will work and won't fall off or melt the paint.
Thanks
Sef
jazzyb
I use epoxy resin the sort u mix also ad a drop of paint the same colour as panels so it doesn't show 8-)
GLscoot
Main scooter: Vespa GS150
i use clear gasket paste as it does not damage the paint work.
sydduckett
GLscoot wrote:i use clear gasket paste as it does not damage the paint work.
Is that adhesive enough, what one do you use?
Ta
GP Kevo
If you peen the pegs slightly you can then use the adhesive to "fill in" the rest of the mounting hole around each peg. Then the adhesive will hold the metal of the legshield to the peg, instead of the back of the badge to the paint.
GLscoot
Yes the gasket paste is strong enough to hold the badge in place, all me legshield badges have been stuck on with the gasket, not sure of the manufacturer. I think I bought it from Beedspeed. I also use it on floor runners a long with M4 bolts and nuts, It stops the grit getting underneath the runners and scratching the paint.
Lambrettatastic
I've always used super glue gel.
Lambrettatastic wrote:I've always used super glue gel.
+1 It works perfect and it's controllable ;)
ducksta
i use black double glasing tape cut it roll into little balls then press and you can get it off at a later date
Herman
Main scooter: GP200
I once used normal super glue which then ran down three or four inches down the the front of the leg shields. I then tried to wipe off before it dried. It left a white-ish mark the size of a saucer that I never managed to get rid of. I wouldn't do that again.
Autobahn
    Users browsing this forum: No registered users and 39 guests
