vespa px150 tuning
thedubdoctor
Main scooter: vespa p150x
members views please ive a new budget of £600,big bore and pipe etc ,don't want much 70mph and a bit of get up and go ,
:D
LI150
Main scooter: Series 2 LI150
My preference would be malossi 166, p2 carb and jl rh exhaust or a revolver.
thedubdoctor
LI150 wrote:My preference would be malossi 166, p2 carb and jl rh exhaust or a revolver.
yes to the 166,sip2port matching,never thought about carb and read vale , want it to look standard at the mo, :D revolver growing on me
ducksta
malossi 166 matched to casings carb and carb box shaped and matched to crankcase crank tuned and polished 24/24 carb polini induction kit + drilled +fast flow tap, flywheel lightend, sip road exhaust.
What bits have you got already, and don't need to come out of your budget?
thedubdoctor
Muttley McLadd wrote:What bits have you got already, and don't need to come out of your budget?
well nothing apart from a px standard pipe with a large outlet and cut about internals,was in a bag of parts ,
so I need everything ,goin down the 166cc route and sip road2 pipe or revolver ,bigger carb be nice ,and some porting ,what about gearing and clutch had a few bits of advice but all conflicting ?
mick1
Main scooter: Li Avanti 225
The £600 budget sounds fine but are you doing the work ? A tuned crank (or altered standard) should be in the list as well. 70mph may be a top end speed but i'd be dubious about cruising much above 60mph (my mates malossi sits nice at 55mph but struggles to cruise at any more than that) .
Regards clutch and gearing.....i'ld leave as is and only look to change if you've got a problem (up-rated clutch spring for £10 may worth a punt).
Herman
Main scooter: GP200
Appreciate that it may not be what you were wanting to do.
Just a thought but if you are looking to spend around 600 would it not be easier to simply source a decent standard P2 engine.
You could keep your 150 engine in case you wanted to put it back. Or if you wanted to sell it, you'd probably get enough for a decent exhaust and a new carb.
Autobahn
Bifter
Main scooter: vespa p210
I have to agree with Herman ,after my experiences with the 166 i would stay well away ,if you insist on doing your engine what about a parmakit ? You won't go far wrong with either of the pipes you are thinking about but the sip will give a little more low down power but the revolver is also good and sounds nice
What about...:
DR180 kit, with a few hours' worth of dremmeling to make the ports a reasonable size - and transfer timing adjusted to run with
A 60 mil crank. Cheap as for Vespas.
24 mil carb (easy to find)
SIP road pipe (cheap - and quiet is the new loud)
P200 gearing and clutch with a short 4th.
If you spend a few hours matching everything up, rather than bashing it in with a hammer, it should run pretty well. It wont set the world alight, but it's not going to suck a tank of gas inside 80km either. And it's not going to be revving at 8000 all the time, so it should last a while too.
