PM End can onto AF NK Road pipe?
some one suggested an aprilia rs125 standard can as I belive they have a mechanical muffler
camel
ive ordered some heatwrap today to see if i can dull the chamber noise a bit,ive got a few jobs to do on the motor so i wont know for a while if it works,as ive said i found some interesting articles on noise reduction,one guy who had a yamaha banshee wrapped his pipes and got the noise down somewhat,he also used FMF turbine core silencers for motorcross use which reduced the noise even more
depechediki
Main scooter: gp ts1225
I recently fitted a PM end can and heat wrap,now sounds a bit different and is lovely and warm ;-)
camel
do you still need earplugs tho????
could try this or ask Darrel it they are any quieter - http://scooterotica.org/forum/viewtopic ... 12&t=24366
Jazzy
Mines got better with age.
Lost that horrible ting from the chamber.
Stil loud but not painfull.
Keeping it in one piece has become the challenge.
Norrie Bodge
camel wrote:seen those Norrie,i was just a bit concerned about the diameter of the bore of the endpipe and baffle as the nk,ads is 25mm...do you know what it is?
specs are all here m8
camel
cheers i did go back to the link and saw the dimensions,the 62mm diameter of the pipe is somewhat smaller than the flange in the exhaust probably wont aid silencing it anymore allthough it does have more length.its obvious the ammount of people posting about noise on the nk/ads pipes there is a major problem...yeah they perform fab but at cost of a lot of noise which is an issue for frequent riders and pleasing the neighbours and dog owners!!!
bigmuff
Main scooter: matt black indian gp
After nearly deafening myself and all around on the ferry back from IOW I bit the bullet and ordered the PM Endcan. Its a couple of inches longer than the NK can and a bit thinner. Fitted fine and what a differnce it makes. Amazed at how much quieter it is. Just sounds slower now though :D
camel
cool...i tried heatwrap and it didnt make a whole lot of differerence...plus the engine block felt a lot hotter than normal to touch with it on so i took it off
ive took the plunge and ordered a motocross leo vince x3 end can after doing some research
hopefully i can get it to fit somehow
glad to hear youve made some progress with the pipe bigmuff as they are way to loud
