rebuilt top end and now it feels"flat??"
tonydevon
Main scooter: '71 GP125
ok sorry if this is a stupid question and I have an inkling that I already know the answer, but having put new piston in, and put motor back together with different timing and squish,it now feels flat and lethargic
pull away is boggy, and the "zing" seems to have "zonged" LOL
I guess that its back to the dyno guy for it to be looked at but would the following changes be likely to have this effect?
old timing was closer to 18 degrees than 17,but barely. new timing is 15 degrees at revs.
old squish was 1.25 before I retorqued the head, didn't check afterwards :( no idea if it would have changed much
new squish is 1.4
changes made after camlam told me that the previous settings as supplied by them were wrong LOL.
bristolmod
I'd run it in first before considering a Dyno session...............
Scootering since 1968.
tonydevon
ok no probs, done about 80 miles on it so far
new piston and rings, but I assume I just follow the same break in as a complete topend?
bristolmod
probably a lot less with just a new piston and rings
I would imagine that it would feel a tad "flater" with the timing retarded and the squish increased, but would recommend that you do give it a period of "running in" before Dynoing- I've always found short sharp cycles work best on a 2 stroke. Short journeys from cold, with bursts of quite normal acceleration, then back home after 2 or 3 miles max and allow to cool. Then repeat, again and again.
Yanker
new squish is 1.4
Honestly?
TD, you have dived in, got involved, shared sorrows, blown a bomb and left this site to commit the above ^ crime?
Ur not taking the p155 are you? .......No didn't think so.
Do RFD have a stall at Exmouth?...do you know?
tonydevon
?que? lol
im confused.
Yanker
tonydevon wrote:?que? lol
im confused.
Si Compadre, Porque ?no?
tonydevon
Im obviously missing a joke or have done sonething proper wrong lol
not sure if im nervous or scared :)
and no rfd wouldnt have a stand at exmouth. not really an ideal audience i think you would agree. but you somehow know who i am and where i work so have the upper hand :)
tonydevon wrote:.....but you somehow know who i am and where i work so have the upper hand :)
If you know Andrew Holburn (Yanker) then its OK, you are safe. But if not......then you have a stalker and should change all your locks at home!!!! Lol :)
tonydevon
Never heard of him.
still trying to work out what crime i committed lol.
maybe he been on the vino? or maybe my engine about to fall apart and only he knows why.
    Users browsing this forum: Semrush [Bot] and 15 guests
