Difficulty starting
vRSG60
Main scooter: Lambretta Li125 Lambretta GP20
Normally starts 1st or 2nd kick but since Sunday if left for a length of time the scooter just doesn't seem to want to know and takes forever to start.
Same this morning ended up push starting it. Yet get to work, turn off try again and it starts 1st kick???
Same yesterday morning but after work it started 1st time - strange.
I did notice this morning I'd forgotten to turn the fuel tap off last night.
I get my kicks out on the floor.
Daggs
You tell us little about the scooter, so diagnosis won't be easy! The first thing that i thought of was the extreme heat over the weekend! Did this play a part?
vRSG60
SX150 engine with a 175 top end. Dellorto SH1 20 jetted as per TV III 175 shown here
The hot weather is probably playing a part to be honest.
Donnie
Given you said you'd not turned off the petrol last night it could simply be your float needle has a little wear and too much petrol managed to get through over night and flooded the engine. I hope thats what it was anyway, if not the first thing that springs to mind is that it could be a break in a coil but definitely need more information I'd think.
Definitely try to have a few days of ensuring you've turned off the petrol and see how you go, it may have been that simple.
Donnie.
vRSG60
Thanks for the replies. If it happens again I'll try starting with the tap OFF to clear the carb then try again.
Minority
Main scooter: Li230 S3
Daggs wrote:The first thing that i thought of was the extreme heat over the weekend!
In England, you jest, surely! :lol:
Daggs
No !! Honestly. It's been over 25 degrees here for about a week..................that's twice since 1876. ............
Global warming.......... :lol: :lol: :lol: :lol: :roll:
vRSG60
Started OK last night and this morning. :D
Donnie
Excellent maybe that's all it was then :D
Donnie.
It's always worth bearing in mind that the default throttle position for starting is closed. Providing the choke and idle circuits are set up correctly it SHOULD fire up easily. Some engines might need a slight variation on this for starting, but most don't. I (like many) used to kick mine over whilst twisting the throttle with the result that I often flooded it :oops:
    Users browsing this forum: Google [Bot], Semrush [Bot] and 14 guests
